Manufacturer: Kenmore
Type of Appliance: Washer
Model Number: 110.4784292
Looking for washer service manual.
thank you
Couldn't find your model since it is probably Canadian. When search found US washer that use the same timer. The washer looks like it is a standard whirlpool direct drive washer. Uploaded the wiring diagram pending approval:
  • Thanks 2
I saw where Vance got the idea it being a DD washer. From eBay listing by Midwest parts listing a timer with the model as matching the part along with a 110.268xxxx model which is a DD washer.
I did the search another way. Isolating the model number by finding previous and following models. I don't know if Kenmore model numbers work in sequence, so this is just a guess. 110.4779xxxx is a front load washer, 110.47852xxx is a very similar front load washer. Anyway, in case you get there and it is not a DD, here are UI pictures and appliacable tech sheet numbers for those models.
Just noticed those 2 tech sheet numbers point to the same tech sheet. Also matches Whirlpool WFW9200
  • Thanks 1
Came across a repair question online describing your exact model and the fact that it agitates, so it probably is the DD washer.
Thanks guys 🙏
@RonenWas it a direct drive or front load just for the record? Have you possibly taken a picture of the tech sheet on the machine?
