Microwave help-Frigidaire model FFMV164LSA
Hello,  having trouble with a microwave.  Every 3-6 months the microwave goes dark.  Line fuse blows.  I can replace the line fuse, then it happens again awhile later.  I have done some reading into what causes the fuse to blow...incoming power/surge, door switches, magnetron...what else.  What is most likely.  I have tested the door switches...all good.  What is the most likely culprit.  I am thinking of changing out magnetron and HV diode.  I have done this before, I know how to unload capacitor.  Thanks for any help
Odds on bet would be door switches or door switch timing.
Vance, I tested all doors they all tested ok.  ????
door switches
So next would be timing of the door switches, the primary and secondary switches have to open before the monitor switch places a direct connection between line and neutral.
Does this happen when you open the door?
No, plus the door switches have been tested. They are all operational.
  • 1 month later...
Had same issue.  There is a service bulletin on this model to where you have to replace the switches and their support.  Apparently the problem is caused by a partially open monitor switch.
  • 2 months later...
I've run into a few of these lately and i found this part # 5304509457 has the support and latch hook and spring. not sure if the door switches come with the support, I will update soon
