      5
Manufacturer: LG
Model Number: Lsc26905sw
Broken water line at door hinge on SXS.  I could not see a way to install new it was as if it is connected behind the dispenser in the insulated section.
Uploading service manual and waiting on approval: That maybe a question you should ask over on the Appliance Repair Tech forum!
The tubing is foamed into place inside the door so even after you remove the dispenser, the tubing isn't a replaceable part.
Also the door is NLA, as is the dispenser.
Edited by Terry Carmen
Thanks, Captain!
