LG washer with no power lg wm2301hw
Hey guys, Washer stoped mid cycle,Display is dead.Have power to and from noise filter and to main pcb board. NO red light on main board (EBR32286014) ?? Tried the re set protocall, Nada... Tested Hall and rotor , Its in spec. Removed cleaned and tested drain pump, its OK to... Same for door latch..  Main board is obsolete and ony a few junkyard ones on ebay Wayyyyy Over priced. Was told that pcb 6019 and 6007 will work but all are NLA!! Only option found is send pcb out for a repair, also not cheap, If I knew a junk or rebuilt pcb will fix this I will be happy to part with my $$$. Super clean machine,Just cant get my self to toss this in the trash? Any advice would be Great ! Thank you for your time.
Best
Steve
  • Replies 1
  • Vance R
  • glassrton
Looks like partsimple or corecentic for rebuilt boards are the best option.
