Ok Senseis My GE pdw7880g00ss dishwasher has a blown transorb (shorted, .5Ohm resistance). Any temporary replacments I can put in until I can get a WD35X10025
Hi, turns out I have a shorted (failed) transorb on my GE pdw7880g00ss dishwasher.
Details can be seen here: https://usermanual.wiki/Pdf/GeDishwasherTransorbBulletin.143718166/view
The transorb is supposed to be 100K Ohms resistance but mine measures at a whopping 0.5 Ohms.
Needless to say I've blown the first, and now the 2nd flood switch before I realized and dug into what was happening as my model has a transorb wired in parallel with the water valve.
According to this helpful post by a different Samurai on here: https://appliantology.org/blogs/entry/219-troubleshooting-information-on-transorbs-used-in-ge-triton-dishwashers/
it's just a
 1.5KE220CA Bi-directional TVS Diode
(about $1)
1500w peak 220v C = bi-directional
with 2 wires on each end. I feel like maybe I'll be able to source a TVS Diode near me, are they easy to find?? (I live in a big city on the east coast US)... even if just temporarily until I can get the overpriced official GE Transorb?
Thanks in advance for any help you can provide!
Check to see if there is a newark or digikey jn your city other wise a web order should get you one.
  • Thanks 1
Thanks, and does this: "1.5KE220CA Bi-directional TVS Diode" seem correct per the first "user manual" post? (before I go an accidentally buy the wrong thing).
Seems like it should work.
  • Thanks 1
