Help needed please - Washer LG FC1408S3E displaying a tE error
rajeewadesilva
Hi All, Greetings from Sri Lanka.!!!
I'm a newbie for this forum joined here to seek your good advice.
My Washing Machine "LG FC1408S3E"
Initially, it displayed an error "tE" which was deemed to be a thermistor error related to heating.
A local repair guy thought it was a door error and messed up with the door switch which lead me to replace the door switch  >:(
However, After replacing the door switch the tE error was disappeared and the washer was back to normal for a month.
Now again I'm seeing this error "tE" Could you guys could kindly advise me on how I could get this problem fixed?
Appreciate your support. I have attached a video and an error diagnosed by the Application.
Thank you and have a great day!!
  • Replies 1
  • Vance R
  • rajeewadesilva
Posted Images
The most common reason for a TE error code is the wires are broken. When the wires are zip tied into the harness they get pinched, the conductor on the inside of the insulation breaks causing intermittent connections. Also possible the thermistor is out of specifications.
