Manufacturer: Samsung
Type of Appliance: Oven
Model Number: Nx58r9311ss/aa
This is a one year old unit. I was unable to find parts for it. The oem igniter was round, I replaced with universal round Frigidaire version. It works but seems like there is an issue opening the safety valve consistently. The oem was replaced as it was broke.
If the original igniter was a round igniter in a rectangular cage, I think you used the wrong igniter.
I believe the current rating on the valve is compatible with the rectangular flat frigidaire 5303935066 ignitor, not the round one.
Check the current rating on the label on valve in the oven.
I think you'll find it needs 3.2-3.6 amps, while the round frigidaire 5304401265 igniter is only 2.5-3 amps, which won't reliably open the valve.
Edited by Terry Carmen
  • Thanks 1
10 4. I was skeptical when I saw the flat case. Thanks for the advise. Im still wanting the service manual if anyone can get it.
Uploading service manual and waiting on approval:
  • Thanks 1
Thanks, Captain!
  • Thanks 1
