Even though the washing machine spin cycle is working, the clothes are being left more wet then usual. I'm assuming its a drainage issue, however, I don't know where to first start checking.
thanks, BDWeller
  • 2 months later...
  • bdweller
  • vallen513
  • Menno
I also am have a machine with the same problem, have you solved that problem?  Thanks
Make sure it is actually spinning at full speed. The clothes should be spun out to the outer edges of the drum.
