Frigidaire LGG3043FFC range ignitor
I have a Frigidaire LGG3043KFC range that I need to replace a couple top burner igniters on.  The problem is that none of the parts stores carry just the igniter, you have the buy the entire burner orifice housing that then has the igniter attached.  Anyone have a suggestion or know the part number just for the igniter?
That is how they come, there is no igniter available directly.
Also don’t be surprised if burner screws strip or snap. These can be tough to replace without replacing all the burners and screws due to snapped and stripped screws.
  • Like 5
That model number doesn't seem to be good, however it doesn't matter much.
You can either buy a fireplace lighter or a new stove. If you try to disassemble it, you'll probably be buying all 4 (5?) orifice holders and a hand full of ridiculously expensive screws.
I'd use a lighter.
  • Like 2
