KitchenAid Dishwasher Model # KDTM354DSS4 - will not wash
My KitchenAid dishwasher is about 5.5 years old and will not wash.  I found the technical sheet behind the kick panel and followed the directions for the Service Diagnostics Cycle.  It looks like I have error codes 61, 71, and 81 which does not make a lot of sense to me.  I would be interested in any thoughts on this issue.
Wilke
  • Wilke
  • CJ Pool
Try adjusting the striker plate on the door latch. The door may not be fully engaged so the cycle won't start.
Thank you for your reply.
I found the problem I believe.  After taking apart the pump, I can see that the Dishwasher Pump Filter is all messed up and preventing the motor from turning.  I ordered one today and hope to receive it by Th or Fri this week.  Will update the board once I install the part.
Here it is Saturday evening and I now have a working dishwasher!  I received the Pump Filter part # W11084156 on Friday evening. It was easy to install following the video on RepairClinic.com
One word of caution for amateurs like myself - Do not hesitate to tighten down the screw-on hose clamps.  I thought I had tightened mine down good.  I noticed a slight leak when I ran the diagnostics again and had to pull the dishwasher back out to retighten the hose clamp screw another 1/4 turn.  Life is good now - dishwasher cleaning dishes and no dishwasher lying on its back in the middle of the kitchen floor.
