Kenmore Side-by-side, ice maker stopped working (106.59422801)
The ice maker stopped working. Valve doesn't open to admit water, the thing doesn't cycle. The position of the wicket (up or down) doesn't make a difference.
I could not find a manual switch.
Ideas?
Thanks!
  • Replies 1
  • thirteenrs7
  • vallen513
If you pop off the front cover of the icemaker, there are two holes labeled T and H. If you jumper those, it should manually start a harvest cycle. Before that, check the paint coating. If it is bubbling or peeling off replace icemaker.
