Kenmore oven (model 911.3022190, mfg. by Roper) not starting up
Hi, this is my first post here. I'm a very amateur DIYer, and running into a problem with my oven. It's a Kenmore wall-mount oven (model 911.3022190, manufactured by Roper) from 1990.
Worked fine until recently wouldn't start any more. Pushing the buttons on the control pad, I can set the temp and time, and it blinks for a few seconds like it's about to do something, but then it just clicks off without going into operation.
Assuming it was a faulty igniter, I got the appropriate one on eBay and installed it, but didn't change anything. Any idea what it sounds like the problem could be?
Incidentally, the clock and timer still work.
  • Replies 1
  • vallen513
  • quaco
Does the ignitor come on (glows)? If not, I would suspect the control board. You pretty much have the board, ignitor, and valve to get it to come on.
