Whirlpool WSF26C2EXW01 Ice maker
My fridge ice maker just doesn’t want to work. I have water in the supply line but no ice in the box. HELP!!!
  • Replies 8
  • tommy3sons
    6
  • Vance R
  • kepbin2003
Find your test ports labeled V and L on the back of the unit. Use something to connect those two and close the circuit. From what you said in your post you are getting water to the ice maker unit. Once you've done that it would just be a matter of taking off the cover of the icemaker component itself and see if any of the terminal leads are burnt/corroded. I would just plan to replace the entire unit. But to verify I'd take out the icemaker unit after you confirm getting water, the remove the screws on the faceplate cover and check the terminals see what you get.
Thank you I will start there
I checked it this morning for ice.  Nothing.  I have water to the door for drinking but I don’t think I’m getting water to the ice maker.  Could have a frozen water supply line I suppose.  How do I check for that? Please advise. Thanks in advance
I’ve tried everything.  I’ve determined that I’m not getting any water to the ice maker.  Now what? Please help
This style whirlpool refrigerator has problems with breaking the wires at the bottom of the door. Need to check for broken wires in the hard plastic tube.
Ok I’ll check that first thing this morning. Thank you
Vance R:  you were on the money. The three wires at the bottom of the door were broken.  Since there is possible movement again, how do you suggest I repair this? Connectors or solder or ? Please advise
Remove as much of the hard plastic tubing as possible. Solder the wires and use shrink tubing, just be careful not to shorten the wires too much. Use a nylon mesh sleeve to cover where the hard plastic tubing was located.
