Kenmore 665.77983K703 (purchased 2010) not spraying water... what's wrong?
Guys, my dishwasher starts to work OK. I can select my washing program, It fills with water and then just sits there ( it drains OK at the end of cycle). It does not spray any water onto the dishes I only hear a click occasionally. Does anyone know what could be wrong? This problem started to happen occasionally but after several start tries it started to wash but now I can't get it to work at all. Oh and I already tried to unplug it and the reset by pressing heat dry and normal wash buttons. Any suggestions?
Thanks a lot.
  • Replies 5
  • 16345Ed
  • TurboLover
Bad circulation motor or bad board need to do voltage tests to determine which.
Edited by 16345Ed
How can I test the motor or the board? Can you post the procedure please?
Do you have a voltage meter?
Yes Sir.
Tech sheet is behind toe under the insulation.
