thepowertowin Posted December 30, 2021 Posted December 30, 2021 Manufacturer: KENMORE Type of Appliance: GAS OVEN/RANGE Model Number: 790.74233314 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): NO Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES (DIDN'T COME UP IN REPAIR CLINIC, VERIFIED THOUGH) 790.74233314 - LOOKING FOR A SERVICE MANUAL - NEED INFO ON IGNITOR SYSTEM, AND ALSO ADJUSTING AFTER SWITCHING TO PROPANE THANKS!
Vance R Posted December 30, 2021 Posted December 30, 2021 Uses this tech sheet. Usually the installation instruction has the conversion instructions, one at sears parts direct didn't have that information. If you done the conversion already just follow the standard setup instructions. 1
thepowertowin Posted December 31, 2021 Author Posted December 31, 2021 15 hours ago, Vance R said: Uses this tech sheet. Usually the installation instruction has the conversion instructions, one at sears parts direct didn't have that information. If you done the conversion already just follow the standard setup instructions. It was converted previously. Customer says that the burners won't go low enough to simmer. I wasn't sure if there was any adjustments.
Captain Dunsel Posted December 31, 2021 Posted December 31, 2021 Installation instruction has the conversion of pub # is 316903000 which you can find if google it.Here is part of a screen shot:
