Supposed 2021 GE dishwasher GDT530PGP6WW need the service manual
Manufacturer: GE
Type of Appliance: Dishwasher
Model Number: GDT530PGP6WW
I tried using the manuals that come up searching this model for Tech sheets, but the common Mini manual for these GE top mount and front mount control Diagnostics mode did not seem to work correctly for this unit. When entering service mode the display shows a 0 and when you try to go into load test mode (by holding start and cycle select while in first step of service mode) any key press resets the user interface back to normal function. Need to know how to activate load test for this unit.
Here you go:
  • Thanks 1
Thank you so much @Son of Samurai and perfect timing to boot heading to this call this afternoon.
