Manufacturer: Kenmore
Model Number: 111.60512912
Looks like a top freezer, simple design.  However, R600a type refrigerant.  Also, is there a way to force defrost on these models?
Much mahalos for your help.
DK
  • Dkauai
  • Vance R
How to start : turn the fresh food temp control dial from step1 to step 7 while pushing door switch simultaneously.
Thanks, Vance I'll try that when I go out.
RC 44 deg.
FZ -19 deg.
Found damper closed off and blocked with ice build up.  Defrosted and reset the damper to middle.  We'll see if this will help.  DK
