    • 15 March 2025 02:00 PM Until 03:00 PM
      When: Saturday, March 15 @10:00 AM Eastern Time.
Manufacturer: GE
Type of Appliance: refrigerator
Model Number: ZIS480NXA
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
I've got 31-9117, but it covers ZIS480NR series, I need the ZIS480NX series.
I replaced the compressor inverter, then as an afterthought, they asked me to look at the LED lighting in the fresh food compartment. Despite testing for the presence of voltage with a volt stick at the wire harness. when I tested the loz voltage at the connection, I only measure .038 VDC.
I should mention that the only lights not illuminating in the fresh food are the ceiling assembly, the other fresh food lights, which I THINK are incandescent, are illuminated. Also, there are no lights in freezer lighting up.
I need to know how the LED light board in ceiling gets power
  • Scott-afl
  • Captain Dunsel
See if this service bulletin helps:
I believe that will, thank you ever so much.
I will test for 120 VAC from orange to white going to transformer primary...
at this point I would assume transformer is bad since I already tested input of CDC power board and measured 0 VAC.
I did not, however, see any fuse in the main control.
Perhaps it is located down near the transformer.
