Kenmore 90 series plus Wrinkle Guard
tperalta
We have a 90 series plus dryer....When put on wrinkle guard it will not tumble.  Other wise timer works fine.  When wrinkle guard is turned off the timer will cycle. Would appreciate any help with repairing this (essential and/or worthless) feature.  Thank you!
  • Replies 6
We do Mad Mac...68932790 68932 also  Type #130-00.  Thanks for any help you can offer. Thanks, Tom
Electric "Even Heat" model. I think we have a tech sheet around somewhere - if poss, can you scan and post yours?
As ever, the ever helpful Ms. Pegi comes to the rescue.....
Intermittent 48 V DC  to operate the motor relay in "Wrinkle Guard" mode comes out of P 1-2 on the board. Check to see it that's there. If not, then it's the board. If it's there, then look at timer contact V-BU.
Thanks!!!  We will give it a go. Tperalta
