Midea Front Load Washer, E50 Error Code, Tech Sheet Needed, any help is appreciated
Gen X Appliance Repair LLC
Manufacturer: Midea
Type of Appliance: Midea Front Load Washer
Model Number: MLH52S7AWW
I've not been able to find anything for this one. Anyone else got something?
I have never been able to find technical documents for Midea appliances. They are junk anyways, parts are difficult to get and quality is poor. If I cannot diagnose the unit without the tech sheet then I walk away. Tell the customer to call Midea and request the tech sheet, and call back when they get it.
Thank you guys.
I contacted  Midea for a service manual and got this. I email them again for a tech sheet and got nothing yet. Looks like a user manual but they call it a Technical Service Guide.Uploading and waiting on approval:
Thanks, Captain!
Just got this from Midea. Thank you for responding. Please be advised this is the only service manual we have on record.Good reason not to work on this stuff!
Thank you.
  • 3 years later...
@Gen X Appliance Repair LLC did you ever find any more info on E50 on this unit, or make any progress on a solution?
I've got the same error on the same model for a repeat customer, haven't been out yet, hoping to find some info for pregaming
@Rhubarb Tau Looks like this is the service manual.
  • Thanks 1
Thanks @Captain Dunsel, that's a much better service manual that the other one I found on the site; it was mostly just a Use & Care. This is perfect, thank you!
Note - discovered this through experimentation, I didn't see anywhere in the Service Manual how to advance in Svc Mode, turns out it's the "STEAM" key, or leftmost button under the cycle wheel
  • Like 2
