Manufacturer: Kenmore -> Whirlpool
Type of Appliance: Washer
Model Number: 110.4698290
Hello and good day,
I am looking for the wiring diagram for an older Direct Drive washer that is loaded with features... The existing diagram is worn. I do have the part number from the corner of the sheet though. Wiring diagram publication # 3946850. Having a water fill issue with I suspect is the 7 switch board and/or thermistor, not working properly for incoming water. The 3 port mixing valve is working.
Model # 110.4698290
Serial # CF2604177
Wiring diagram 3946850
Thank you.
  • Replies 4
  • Kylebravo
  • Son of Samurai
  • Captain Dunsel
  • Vance R
Servicematters is not giving me any wiring diagram for that number you gave me which is I sure is correct and the model number does not pull up for me as we know this is a Canadian model. I’ll keep searching but maybe @Vance R can find something when he gets a chance.
Well couldn't find that model or tech sheet. Found this one while looking around looks like it maybe close pending approval:
Thanks, Vance! Approved.
Thank you
