GE Specter XL44 Propane Range - Oven does not maintain temp
Rick Gulack
Oven lights and comes up to temp,  then does not relight to maintain temp.
  • Replies 1
  • EngineeredAppliance
  • Rick Gulack
EngineeredAppliance
Would need a model number to better serve you. However it sounds like you have an issue with the thermostat, and/or the temperature sensing device. Your igniter should be good seeming how the unit comes up to temp initially. Are the controls analog/dial or electronic? If electronic I’d say control board is faulty. If analog I’d say the thermostat w/sensing bulb is out of spec. If electronic add in a temp sensor for good measure that model it may be only 20 - 30 bucks extra on top of the board.
