AWN632SP116TW01 Speed Queen Washer Service Manual request.
Manufacturer: Speed Queen
Type of Appliance: Washer
Model Number: AWN632SP116TW01
The unit includes a very basic paper schematic inside the control panel and it makes reference to trouble codes and another service manual, but it doesn’t tell you how to access the codes or the other service manual. It’s that main service manual that I need.
Thank you!
  • Replies 4
  • Fixitrightthefirsttime
  • Captain Dunsel
See if this helps:
1 hour ago, Captain Dunsel said:
See if this helps:
Thank you Captain Dunsel,
Is there a way to access a diagnostic mode on this model in order to inspect error codes or do you just have to wait just for them to pop up. The problem I’m having is that this machine as soon as you start it goes straight to agitate skipping the fill cycle. This happened after it was flooded. The control board that sits adjacent to the motor has since been replaced. Another motor and even pressure sensor was also tried, but still having same issue.
I am sure the board does not store codes and you have to wait for them to pop up! Check your PM!
Ok. Thank you!
