Manufacturer: Gaggenau
Type of Appliance: Dishwasher
Model Number: SHUGGE1UC/12
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
Looking for a service manual. wash pump motor would run non-stop as soon as powered up.
  • Corno Gobbo
  • TheHelicopterKid
This one will work for your model. As for the pump running - in most cases it would be the drain pump running like that rather than the wash pump. See if there is water in the lower tray, activating the float switch.
thanks for the Manual.  It was the main pump motor.  I had it out and both of the sides removed, the red diddle stick wasn't stuck and the drain activated if I raised it myself.  I was able to put into a test mode and then after that it appeared to be back to normal.  leaning toward the MCB,  had 9. something amp draw on the heater in test mode  but 0 amps when I ran a normal cycle.  Not sure if I waited long enough though.
