Samsung washer model WF350ANN/XAA issues
This washer trips the gif outlet intermittently but often. Now it is nor draining. Drain pump? I also saw a 6E error on the display. Any help appreciated.
  • AWSHandy
  • mvtvnc
  • Metro Appliances
Couldn't find a WF350ANN/ Found WF350ANW/XAA and usually 6E has to do with the motor hall sensor signals come out without motor operation.
  • 2 weeks later...
Resolved: protective mask lodged in drain tube between outer tub and drain pump. Removed mask, that was it.
Good find
