Puzzled with this one. No heat. I replaced the igniter, coils, cycling thermostat, thermal fuse. Tested all other thermostats for continuity. When I turn it on, no ignitor glow. No current thru thermal fuse. No voltage to ignitor. What am I missing? Thanks.
I did check all the connectors for good connection.
Yep, gotta check timer to the timer chart
FIXED- replaced timer. Works like a champ now. I wish I knew how to check timers. Would have saved time and $. I will figure that out if faced with this issue again. Trouble is, the thermal fuse tested bad and that is such an easy answer.
