AllStarBob Posted May 5, 2022 Posted May 5, 2022 Manufacturer: Thermador Type of Appliance: French door bottom mount Model Number: T36BT820N3/25 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): No Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes When I search for this model BT71's show up no exact match for this unit at sears. I need to connect the house water to the ice maker which is in the freezer, there is no drinking water on this fridge. in the back there's an approx. 5/8 plastic tube sticking out which looks like it runs up to the front where theirs two solenoid valves and a water filter and everything is very tight. With out any info on it i'll have to pull the hole thing out to see how it works. My thinking is the 5/8 tube is to direct a 1/4" thru, it would just help if there was some kind of instruction and thank you for all you do.
Team Samurai Son of Samurai Posted May 6, 2022 Team Samurai Posted May 6, 2022 Should use this tech bundle:
