Whirlpool Dishwasher Model WDT780SAEM1 Stops Mid Cycle
Unit is 5 years old. Starts cycle, fills with water, cycle starts normally but just stops after a few moments. This happens on all settings. Diagnostic shows F6/E4. No leaks are visible. Checked supply line, checked drain line. Unplugged unit to reset but still have same issue. Removed unit from cabinet, tilting it to remove all water. Please advise…Jack
  • Replies 4
  • Jpsbgt
  • 16345Ed
  • Stronghammer
Does it fill with water, and drain properly?
Very possible that the wash motor is malfunctioning. I’ve run into a slew of these where the wash pump either draws too much current and the control board cuts off power to it, or the pump’s motor ohms open. I’d ohm-out the pump (light blue wires) to start.
Thanks! I have determined that the wash motor pump is bad. I ordered a clone for $59.00 delivered, WP wants $250.00 for the pump which can fail in less then a year, bad design of motor and it’s graphite bearing . Will update the outcome.
Changing wash motor when you have a leak sensor error?
Good luck with that.
You need to determine why leak sensor is being activated(source of leak)
  • 3 weeks later...
16345Ed
I guess you think you know it all right ? Absolutely no leaks present. Replacement clone wash motor cured the issue. And I even managed to replace just the motor portion of the pump. Most don’t realize that it is not necessary to swap out the entire assembly. $59.00 for the part. Afterwards the F6 E4 code was gone.
