Hello
I've determined that my KA KDPR407HSS oven's thermostat / brain is shutting down temps 15 degrees before the temp I set the oven to. I believe I need to calibrate the oven by adding +15 degrees but I don't know how.
Here's a link to the manual.
https://www.manualslib.com/manual/88279/Kitchenaid-Kdrp407h.html?page=14#manual
and Technical Education manual
https://www.manualslib.com/manual/1583378/Kitchenaid-Job-Aid-4317282.html#manual
thanks, Steve
  • bingo
  • 16345Ed
Curious how did you make this determination?
Btw I don’t see adjustment procedures anywhere. Did you also test temperature sensor?
That’s not proper procedure for calibration.
You need thermocouple in oven. Set oven to 350. Let oven cycle 4 times recording high and low temps don’t open door. Throw out first set of numbers. Then average other six numbers to get your average oven temperature.
