Manufacturer: Whirlpool
Type of Appliance: refrigerator
Model Number: GD5RVAXVY05
Need something on diagnostics, needing to run test on despenser motor.
  • nowscjh
  • Captain Dunsel
  • Freddy B
Uses the same tech sheet as this model:
There has to be a way to do dignostics on the refrigerator I'm working on, this has the 6 buttons on the ui. Its b4 whirlpool started doin the 2 buttons on left to get into diagostics. The despenser motor not getting voltage that comes from the main control board.
Paddle input is good.
Wiring diagram is probably pretty close.
  • 2 years later...
Did you find the fix? I’m going to work on this exact fridge with this exact issue.
