Iceburgthagreat Posted May 17, 2022 Posted May 17, 2022 Manufacturer: Frigidaire Type of Appliance: Stand up freezer Model Number: LFFH21F7HWJ Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes .jpg
Terry Carmen Posted May 17, 2022 Posted May 17, 2022 I don't see "F" documented as any sort of code. Is the compressor running? Is the fan running? It's a pretty simple machine. The controller runs the evaporator fan and compressor when the thermistor indicates that the box isn't cold enough, and there's a heated defrost that runs every 12 hours.
Captain Dunsel Posted May 17, 2022 Posted May 17, 2022 Extreme or Quick Freeze Pressing Extreme Freeze or Quick Freeze key turns the compressor on for 72 hours. The Extreme Freeze LED (if so equipped) is illuminated when this function is engaged and the acceptance tone sounds. The display will show “-F-”. The Extreme Freeze key toggles the state On or Off. The user is allowed to change the set temperature while in Extreme Freeze mode. The new set temperature will be used when the Extreme Freeze cycle is complete. Defrost will function normally during Extreme Freeze. If Extreme Freeze is activated during defrost, the LED and the display will reflect the mode, but the compressor will not come on until after the defrost cycle is completed. Extreme Freeze will not engage if the temperature setting is “OFF”. The freezer will return to the previous temperature setting after the 72 hours. Page 3-5 in this service manual: 1
