Sears Kenmore Dryer (Canadian) 592.89032 won't shut off on it's own
Hi and thanks in advance you any help/suggestions provided.
I believe that this is a Samsung made Kenmore dryer.  It currently does not shut it self off when drying using either a timed dry or the auto sensing dry.  It does shut off if I open the door.
About a month ago it would shut itself off towards the end of a drying cycle and display a HE error code.  The unit felt a bit hotter than usual.  I cleaned out the duct work (it was bad) and found the there was a lot of lint build up in the lint trap area.  The shop vac and some smaller sized vacuum wands were my friend here.  I was surprised at how much lint I pulled out.
No HE error code now, but it does not shutoff.  Floundering through thinks on google seem to suggest the control board.
Does this sound right?
Thanks!
  • Replies 4
  • towtruck
  • 16345Ed
Posted Images
Most likely is a welded relay on main control. Need to test relay with meter to verify.
Sometimes you can tap the relay with handle end of screwdriver to free relay. Might work for a week or two years.
Thanks!  I'll try that this morning and post how it goes.
That seems to have done the trick.  Hopefully it will last more than a week or two.
Thank you very much!
