Manufacturer: Whirlpool?
Type of Appliance: Washer
Model Number: 110.5072010
Found 0 here
mn=110.5072010 sn=C21722028
spin lite on still full of water won’t advance nor pump out dependably.
control board not getting voltage correctly at pins was low  Ordered and replaced board and recalabrated board took over the 2-3 minutes but worked for 2 loads  now doing it again
it did pump out when reset, recalibrated.
  • Replies 4
  • Far field
  • Vance R
Uses this one:
Vance this is a parts manual and it looks correct.
do you have access to a tech sheet? Tech manual? Wire diagrams and entering diagnosis mode?
opps should be this tech sheet:
This one will work Vance thank you much.
