Model Number
SHP865WF5N
Brand
Bosch
Age
1-5 years
My Bosch dishwasher is just over 3 years old. Of course the 3 year protection plan ran out in March and now I‘m having my first problem. It won’t complete a cycle. I found it with water in the bottom of tub and about an hour left on the cycle. I cant just hit start, as if when you open the door mid-cylce. I needed to reset and start a new cycle. Water will drain and new cycle will start. Regardless which cycle I select, it will stop at some point during the middle of the cycle. Please help. Thanks.
  • 2 weeks later...
  • EngineeredAppliance
  • Sam V
  • Hawaii
EngineeredAppliance
Possible bad heater, turbidy sensor, thermistor, or control board
  • 1 month later...
This is due to the bad water count sensor. I had the exact same issue. This is a simple sensor embedded inside the water matrix on the size. You can check function with a multimeter
