How to connect Whirlpool GMC305PRY01 Microwave/Oven Combo to 220v power.
MeanderingThru
hello, and thanks for taking a moment to read my post.
I recently purchased a Whirlpool GMC305PRY01 wall oven and it is missing the wiring that comes out of the unit.
I'm familiar with 220v installations, but wanted to verify my assumptions and was hoping someone here could help.
It appears that I would make the power connections to the suppressor (used parts manual to find name) at the P1, P3, and P4 positions?
check out the attached pic to see what i'm referencing, i may have the name wrong.
Thanks for any help!
That would appear correct. Your L1 and L2 would go to red and black and neutral would go to white.
No, that's not for connecting to the house. That's the filter.
There should be a large armored cable coming out of the oven containing 4 wires. This is what gets connected to the power.
Edited by Terry Carmen
MeanderingThru
Thanks for replies.
I bought the unit used, there was no wiring/flexible conduit coming out of the unit.
I assumed the (un)installer found it easier to disconnect at the suppressor to install the new oven... rather then at the electric box/wire-nuts/cover
You'll need to compare the parts diagram to what you have and order whatever is missing, and also compare what's there to what's in the wiring diagram to make sure there's nothing dangerous going on.
So you bought a used wall unit with no power supply cable.
I wonder what the chances are that it works?
Not sure, but I just checked and there are pretty much no functional parts available for it.
