Samsung dryer dv45h7000ew/a2 no heat
Reverendekim
I have a no heat issue. drum tumbles, no error codes are being thrown. I thought the thermistor was bad. But I think I didn't test it correctly. Regardless it was 7 bucks and I replaced it. I replaced the motor bc the centerfugial switch looked worn out. Still no heat. I have 120 on my heater element but still no hear. Is this a control boad issue? If so how can I test the board?
  • Replies 4
  • Reverendekim
  • Tim M
  • 16345Ed
Reverendekim
Can the relays be tested? If so how?
Should have 240. Need to trace voltage determine which you are missing L1 or L2. Then trace that back to its source to see where it’s being lost.
start at outlet
Reverendekim
start at outlet
Sorry ment I had 120 on both sides. At this point everything but my touch panel has been replaced...
