The problem is that when you select a cycle and press start, all the leds start flashing. I turned off the power for a few minutes then turned it back on. I put it in Error Mode. There were no errors indicated. Then, I put it in Service Mode and it ran thru all tests. No problem. Every function worked. The I exited service mode and put it in error mode. No errors. Still, the problem persists. You press start, and all lights flash. Suggestions appreciated.
  • AWSHandy
  • Fix y'All
  • ServiceTech_Daniel
ServiceTech_Daniel
usually that indicates a open door when all the led flash. Have you tested the door switch for continuity? Since you ran it in diagnostic's and everything ran i am assuming it's fine, but i would check your switch.
Nothing wrong with the switch. What about the blinking lights?
Shot in the dark but possibly the control lock or "child lock" is active
