DCS RDS-305-SS Inner Bake Element Not Heating
The inner bake element in our dual fuel DCS RDS-305-SS is not heating enough to get "red." It gets warm or hot but not hot enough to be red like the outer element. The outer element works fine. The thermostat controls the oven temperature at the desired setting.
I measured the resistance across the old and new inner elements (yes, I have a spare) and they are identical at 19.3 ohms. I replaced the original element with a brand new spare and, no surprise, get the same result. While I had it apart  I measured the voltage across the terminals without the element in place and got the following:  0 volts with breaker open,  18.4 volts with breaker closed and oven "OFF", 84.3 volts with oven selector in "BAKE" mode. The voltage measured in "BAKE" mode did not change when moving the temperature setting. I also measured the voltage with the selector switch in "CONVECTION"  and "BROIL" modes and got 15 to 17 volts. I have looked at the schematic for the RDS-305 and the inner bake element is rated at 966 watts at 141 volts, so i expected to see around 141 volts but only got 84.3.
I am wondering if the selector switch has gone bad and may test it next. I would appreciate any suggestions for troubleshooting this oven problem?
JPC3306
  • Replies 4
  • jpc3006
  • dfphoto
  • JJH1942
  • Lectronics
Update. I checked the selector switch and it seems to be fine. The other device in that heating circuit that I did not check yet is a 50% Pulser. Does anyone have a procedure for checking the operation of a Pulser?
thanks,
JPC3006
  • 2 years later...
I have the same issue.  I went through the exact same steps with similar results before I found your post.  Did you ever resolve?  The wiring diagram is a bit confusing to me.  Appears as though the BK2 works in series with the broilers in BK mode.  Not sure I understand why it appears that way.
I don't have your schematic but probably the relay is bad
  • 2 weeks later...
Hello All,
I also have an inner element in the oven that is doing the same thing. One side has 120 v to chassis ground, the other connection on the inner does not show any voltage to ground when switched to bake.  Oven operates as needed, but that inner element does not get hot enough to glow like the outer bake element.  Broiler is fine.
Happy New Year for '25
