Kenmore DD washer wiring diagram needed. Buzzes and won't rotate in wash or spin.
Manufacturer: Kenmore
Type of Appliance: washer
Model Number: 110.20932994
Washing machine just buzzes in was or spin. We removed the drain pump and that didn't change anything. It spins freely in both directions by hand. Suspecting motor or timer but hoping to get a wiring diagram so we can decide which part. Any help would be appreciated.
21 minutes ago, Samurai Appliance Repair Man said:
Sears info blockade on this one-- can't find a tech sheet.
If you need tech help, start a new topic in the tech repair forum. https://appliantology.org/forum/4-appliance-repair-tech-forum/
Matched the timer from this direct drive washer to a parts list on another washer that mentions LIT8519515 as the tech sheet and LIT3955336 as the wiring sheet.
I got those same numbers off the parts diagrams at Sears Parts Direct when I first looked for the tech sheet on Service Matters. No joy.
