Manufacturer: Thor
Model Number: HRF3601F
Tech service manual request please and any service bulletins available.  Unit has ice maker issues.
 Thank you
Here you go, It may have to be approved.
Any clue when approval will be completed?
 Thank you 🥶
I believe they will post it.
Michael
It would be easier, Can I load a pdf file? How can I do load it?
Michael
Upper left of home page.Click downloads. Click submit a file. After that window opens Submit a file. Then you see Select and the down arrow.Click that.Appliance Repair Manual Pot Luck Supper appears.Click Continue. Then follow directions on screen.
I will try it now.
Michael
Thank you Michael…..
I will check back….
FridgeMan🥶
Thanks, Microns! Here it is:
Thank you to all, great appreciate the help.  Headed to call now, great timing.
Thanks again
FridgeMan🥶
What is the problem with the refrigerator?
Michael
Issue:  ice maker was not producing ice and water leaking.  Found bad FZ door gasket and cracked ice tray.  Ice tray appears it could be a constant issue due to questionable material.  Any clue who makes Thor Kitchen refrigerators tag says made in China.  FYI …Member stated not pleased with unit…Would not replace with same in the future.
 Thanks again for your help Michael….and others…
Some of the early refrigerators are made by bosch. This one is a bosch HRF3601F is the same as HC - 767.
Michael
Thank you Michael….
