Manufacturer: GE
Type of Appliance: Ice maker
Model Number: WR30X10044
Ice maker is not sending power to the water solinoied. Would like a manual to make sure I can kick it off right to do a thorough diagnosis.
Do you have the model number of the machine that ice maker goes to? I'm not finding any information under the ice maker's own PN.
Yes I do. CSX22GRZAWW This is all generated when I ordered a WR30X10093. When I got it the tech sheet that I received to diagnose no power going to the water solenoid. I soon found out that they sent a WR30X10044. Ok, it has no microswitches, totally electronic and the tech sheet did not work. On the back of the ice maker was the part # that I started this request with. So, the tech sheet that I need to be able to kick off to see if power is going to the solenoid isn't available.  When I put that part # in marcone it comes up with WR30X10093. This all started when the original ice maker quit and I ordered an "oem" ice maker. It is not the same as the original, an easy old ge ice maker. So, the questions that I need to answered are not in the tech sheet I received in another thread. This is the second ice maker and I'm starting to look stupid over a simple ice maker. I cannot kick it off to diagnose...(😑
Original ice maker was a WR30X318 and changes to the WR30X10093 ice maker which is Electromechanical. Sounds like you got the wrong ice maker!
According to Marcone it does sub over. I talked to them this moring and they said they are not sure how I got that # as they don't stock it anymore. Frustrating. Thanks for the help. Another one on it's way.
