KitchenAid Dishwasher KUDS25SHBL1- Need Touchpad (User Interface) key switch resistance check table
The touchpad for KitchenAid Dishwasher model KUDS25SHBL1 appears to be faulty. Wash cycle buttons illuminate but start button does not activate cycle. In order to confirm whether its the touchpad or the control board that is faulty, I want to first perform continuity checks on the ribbon contacts. The touchpad connects to the control board via two side by side connections. The connection to P1 has 14 contacts. The connection to P13 has 3 contacts (only 2 contacts are active). Can someone help out with a key switch resistance check table for this model? The part no. for the touchpad is 9743995.
thank-you
  • Replies 1
  • Vance R
  • bcuthbert
Posted Images
The tech sheet has very little info for the ui. The drawing only show 3 wire for P1, P13 is for the rinse aid switch. The table mentioned is just a part number chart for various models. Have you tried putting the dish washer into the diagnostic mode? - high temp, air dry, high temp, air dry or power scour, air dry, power scour, air dry
