Hi, I have Electrolux fridge model EI28BS65KS4 and the water dispenser is not working. I measured the voltage at the main water solenoid (yellow) and did not see 120VAC when the water lever is press. Also, when selecting CUBE dispensing(instead of WATER dispensing)on the front panel  I do hear the peddle opening and the same when CRUSHED. This indicates that the lever switch is working ,right?   also, should the other solenoid activate when the pressing the lever when the UI is in CUBE or CRUSHED mode?
I want to exhaust all possibility before buying a second main control board , I purchased in Jan/2022. BTW, I never tested the water valve with the new board until recently since I didn't have the water line connected until couple weeks ago.
THanks
Max.
  • Replies 0
  • max999
