GE refridgerator model # gth21kbxaww leaking alot of water from front, blue catch tray is always dry.
older model GE leaking water , i regularly clean out back motor and fan compartment , the blue catch tray for water is always dry but alot of water comes out at bottom from both sides all the time ,  again Model #:  GTH21KBXAWW  thank you so much for anticipated assistance ----- clark
  • 1 month later...
  • PitstopAppliance
  • AbygaeleNudelman
  • clarkgable
I don't have an answer for you- but we had the same exact machine with the same exact problem today!
AbygaeleNudelman
There are several things that could be going on: if you have an icemaker on this fridge the water valve or valve connectors could be leaking, the defrost drain could be clogged leading to water leaking, or the defrost drain pan down in the machine compartment could be cracked also leading to water leaking. Just some places for you to take peeks at! Good luck!
