Manufacturer: Kenmore
Type of Appliance: Dryer
Model Number: 110.95862400
Kenmore dryer tech sheet 110.95862400 request
  • Replies 5
  • Captain Dunsel
  • m.clamps
Uses the same tech sheet as this model:
Hi thanks for the quick reply. Would you be so kind as to explain how you found that? I seem to be having trouble locating
things with different combinations of numbers and wildcards before and after. The only search result hits I get are backing off to the prefix (i.e. "110*") which gives me lots of worthless junk. How to look within posts to see cross-reference? Thanks
@m.clampsYou see it under(Top and console parts) and in this case is 1A:
I do! Thank you. that is a very useful tip
