crapscallion
So my almost 3 year old dlex3700v lg dryer is occasional flashing all lights on control panel while trying to make the noise it makes when you turn it on. It's like it can't quite get all of that noise out and has a stutter. It still seems to be drying clothes, but sometimes when it's spazzing out like this it will power down and refuse to turn back on. The only way I've been able to continue to use it is by going to the breaker box and flipping the breaker off and then back on. Then the dryer works normally again, but still spazzes out eventually. I tried the hard reset, I tried the smart diagnosis which said nothing was wrong, called and talked to LG, and have gotten nowhere. Is my power switch going bad? Some sort of electrical issue? Any suggestions would be awesome. Thank you.
  • 8 months later...
  • JulianFarley
  • crapscallion
Did you ever figure this out? I have a service call I’m going to and it’s the same exact model number and same exact symptoms.
crapscallion
No I didn't. I sure would like to though.
So your dryer is still working after all this time?
