Manufacturer: Whirlpool
Type of Appliance: Dryer
Model Number: WED8127LW0
The dryer does everything but start. The model I’m working on is WED8127LW1 but RC only had WED8127LW0 listed.
  • CullenG0
  • Captain Dunsel
All thermostats test good. No belt switch, though shown in the Wiring diagram. No shorts in the motor. The UI counts down when start is pressed, you can hear the relays switch there’s a quick flash of something on the screen and then the timer appears bit nothing happens.
Edited by CullenG0
Added info
That tech sheet does not come up on service matters,but you should be able to use these:
  • Thanks 1
Thank you Capt. - It’s truly appreciated
