Could anybody ID this componant please?
Hi, I have found a burnt out componant that I can't identify. It is identified on the circuit board as PTC1 and is a small rectangle shape made of carbon. I take it that PTC ia a thermistor? Is there anyway I can obtain this online. How can I find the value of this componant, it has no identifiable letters on it.
Other than that is there a way I can replace the whole board. It is a Cuisinart Product?
Any and all advice welcome,
Cheers
Forgot to mention... It is  a Cuisinart SSB1U soupmaker/blender.
Pretty sure that is a Varistor.
Burns out on major power surge - it is designed to clamp lower power surges but can only handle so much, (usually directly connected between line and neutral - near the main power input).
What does a varistor do?
Varistors are used to protect a circuit from high voltage surges. When a high voltage surge is applied to a circuit, the outcome is usually catastrophic to the circuit. A capacitor may be installed across the signal lines. However, this capacitor cannot suppress voltage surges
A varistor is a voltage dependent resistor (VDR). The resistance of a varistor is variable and depends on the voltage applied. The word is composed of parts of the words “variable resistor”. Their resistance decreases when the voltage increases.
What happens when a varistor fails?
Under different current conditions, failure modes include electrical puncture (see Figure 4), physical cracking (see Figure 5), and thermal runaway. Cracking happens because varistors are basically a ceramic material, and hitting them with a sharp high-amplitude surge is like hitting a dinner plate with a hammer.Aug 31, 2020
I think the blue things are the MOVs (Metal Oxide Varistors).
PTC should be a Positive Temperature Coefficient thermistor, but that's pretty huge and doesn't look like any I've ever seen, so I'm pretty much out of good guesses. 8-)
Edited by Terry Carmen
@Terry Carmen You're right, I missed the round blue disc Metal Oxide Varistors.
That maybe a power supply capacitor across the line to filter power supply noise.
I have a Whirlpool range control board with a similar component burnt out and it's Metal Film Non-Polarized Capacitor, (not burnt up like the one here but side blown out and melted silver innards came out one end).
Thanks all for the info. I am hunting down another one for parts.
