Whirlpool washer WTW6700TU1 will not start
Problems,problems......
Whirlpool Cabrio WTW6700TU1 washing mavhine.
While washing a load, I guess it got unbalanced and stopped.
Went to restart and all it would do is make a bunch of clicking noises.
Now it will not even do that.
After unplugging and letting sit for a few, plug back in, hit power button, everything lights up like normal.
Now it will not even make any noise after hitting power button.
Hit start and everything starts blinking and nothing will work or quit blinking until unplugged and plugged back in.
I pulled the lid lock off and took it apart and hooked 12vdc to the motor and it works.
Put it back together and installed and still same problem.
I have searched a lot and can not find any tech sheets or info for my particular lid lock.
Or my machine with that particular lid lock.
It has a 7 pin wire holder with 6 wires in it.
I did find one tech sheet with the same configuration and number of wires, but not the same color wires.
Mine are: white, brown, black, green, green, red.
Lid lock assembly part# is: W10059230.
I went ahead and ordered a new lid lock and should be here today,.. but...I do not think that is my problem.
Does anyone have any ideas ?
Or any free tech sheets or service manuals????
I pulled the clothes out and it is sitting with a bunch of water in it now.
  • Replies 1
  • MrApplianceMatt
  • Timehunter
Posted Images
Have you investigated a drain pump failure? If the drain pump fails and the control sees an issue with the water level system it will go into flood mode and run the drain pump for 10 minutes forgoing any other function. The tech sheet is usually stuck to the inside front left of the washer cabinet in a plastic envelope.
Edited by MrApplianceMatt
