Small amount of water leaking through the water/ice dispenser on a Samsung french door fridge
I have a small leak through the ice dispenser. In fact when I open the fridge door, I can see some droplets on the edge of the gasket that goes under the ice maker. At first I thought perhaps the gasket wasn't making a good contact with the ice maker. Although I did not see an issue, I replaced the gasket anyway. Unfortunately that did not solve the issue? Does anyone know what else may be wrong?
Is flap closing tight?. Good test is pour water down ice chute on door from inside if water goes through flap it needs replaced.
Thank you for the reply back. The issue appears to have been resolved. I should have realized that it might take some time for the interior temp of the ice make to decrease following the gasket replacement.  I no longer see any water dripping from the flapper.
